Tapping Noise When PTO is Engaged
Diamond E Farm
L3130 & M9540
May 8, 2015
Mullins, SC
I have an L3130 and I have started hearing a tapping noise about midway the tractor on the bottom side when I engage the PTO. What might that be???
Diamond E Farm
L3130 & M9540
May 8, 2015
Mullins, SC
I just found out that it does not make this noise when nothing is connected to the rear PTO shaft. I had a 3 pt. seed spreader connected when I heard the noise.
4,623
Have you greased the u-joints on the pto shaft?
Paulemar
BX25, 60" MMM, 3 point hitch, 60" front plow, 48" Phoenix rototiller.
Jan 21, 2012
112
Pittsburgh, Pa
Check to make sure that the PTO shaft is centered and doesn't have a lot of play swinging side to side. I had that problem and found that the PTO shaft coupler where it goes into the tractor would nick the stabilizer. It was especially noticeable when I raised my tiller and made a turn.
