Tap/Thread size for BX25 front hubs?
origami
'12 BX25. Previous: '95 B1700
Apr 18, 2016
62
Leesburg, VA
I have damaged (or debris-filled) threads on one position of my front hub after the old lug bolt seized. I'd like to run a tap through to see if I can't restore the threads. Does anybody know what tap size I should use? Measurements indicate it's an M14x1.5 but I'd like to confirm before ordering. Any other advice is welcome. Thanks.
4,114
why not just use a 9/16-18 tap ? If you don't have one, grab a grade5 9/16-18 bolt and run a dremel cutoff 90* to the threads? Even a fine hacksaw will do the same.oil it, in 360 back off 90, in 360 back off 90, in ............
Jay
origami
Apr 18, 2016
62
Leesburg, VA
Reporting back to confirm that the front lug bolts are 9/16 - 18 TPI. Thread restorer worked great.
Thanks all.
Sent from my Pixel 3 using Tapatalk
