Takes multiple key turns before starter will start turning - L2550
Stinger23
L2550 w/LA400 Loader
Jan 9, 2025
56
Basehor KS
When I try to start my tractor, I always have to turn the key to start multiple times before it will engage the starter. Each turn of the key will get a solenoid "click" and after somewhere between 5 and 30 key turns it will finally let me crank the engine. It seems like it takes way more "clicks" after it's sat a while and less "clicks" if it's recently engaged the starter.
On a car I would say it's the starter solenoid but I haven't been able to locate the solenoid on this tractor. Is it in the starter? Is it hidden somewhere that's difficult to find?
The other possibility is the key switch but since I always get a "click", I would think that would eliminate the switch as the culprit.
A bad starter is also possible but the click is not the starter engaging in the flywheel and then refusing to turn so I don't think this is the likely culprit either.
Any thoughts on this or info regarding starter solenoid location? Thanks!
8,700
The Starter solenoid is on the starter.
Your problem could be the main switch, safety switch or the starter solenoid.
Quick test, make 100% sure tractor is in neutral and the brakes are set.
Then go to the starter, you will find a small wire attached to a terminal on the starter normally black white stripe, that's the solenoid wire. use a short piece of wire and jump that small wire connection the the Positive cable on the starter, if it cranks right away, try it several times, if it does it consistently you will need to figure out if it's the main switch or the safety switch, as the solenoid and starter are fine.
Check back in if it passes the solenoid test.
3,534
As per normal @North Idaho Wolfman gives great advice.
However, I must say sir, that you sound like a very "determined" person to turn that key 30 times......I would have thrown my hands in the air and started cussing at around the 3 mark......
Good luck, and let us know how it turns out. (y)
Stinger23
Jan 9, 2025
56
Basehor KS
Yes, it gets a little frustrating but I know it's coming so I just turn it real quick over and over until the starter engages once, then I know the next turn it will work again. Only takes maybe 10-15 seconds total before it's cranking.
Dustball
2016 B2650HSDC
Sep 15, 2023
409
265
Hudson, WI
I watched a Mustie1 video recently of a very similar issue and his troubleshooting steps along the way. He (sorta) figures out what's going on at the 1 hour mark. It's a good troubleshooting process to follow to determine if your issue is at the starter/starter solenoid, ignition switch, or somewhere else along the way.
5,646
go to www.kubotabooks.com and download the l2250-l2550....PDF WSM ( 3 parts ).
If this is yours, there's only ONE 'safety switch' between ignition switch and starter so super simple to troubleshoot.
Now depending on age and hours, the ignition switch could be 'wore out'.....
Workerbee
Zd21
Mar 1, 2020
303
161
MN
I have a jd 318 that I use at the cabin. It was doing that same thing, turn the key, off and on, click click until it would finally go. I finally figured it out, it was the spade connectors that go onto the starter solenoid. Cleaned those well, and tightened them up a bit so they fit firmer. No more issues since.
Stinger23
Jan 9, 2025
56
Basehor KS
I did some voltage drop measurements and such and determined that the problem was the spade connector at the starter so I cleaned it and squeezed the prongs tighter and slid it back onto the starter and did about 10 straight key turns that engaged the starter so this problem appears to be resolved.
farmboy24
G5200HST
Jan 13, 2024
E Texas
farmboy24
G5200HST
Jan 13, 2024
E Texas
Had the same problem with my L4300 DT. May take 5-6 tries before the starter would kick in. Got down at the starter and wiggled the wire going to the solenoid and it felt like it slipped into the connector just a hair. Problem gone----for now!
farmboy24
G5200HST
Jan 13, 2024
E Texas
🐒 Wut-chew tawkin bout fawm boy?
Talking about the same problem that Stinger 23 was having with his tractor failing to start--only after several "clicks" getting contact in the solenoid. Loose/intermittent connection on the solenoid wire at the starter.
airbiscuit
New Holland T2310, New Holland TC21D, Kubota l3010 GST, Farmall H
Mar 18, 2021
310
301
NW WI
I had the same problem with my L3010. It turned out that the terminal end where the positive battery cable connects to the starter was nearly corroded off.
