Tach cable Lube?
yamiacaveman
B3200 hst
Sep 16, 2023
Pa
So Ijust bought a OEM ctach/hour cable for my Kubota. Looking for recomendations, before I need to install -- Do I need to lube? Should I lube? and if so what should I use to lube the cable?
Thanks for any suggestions.
Roadworthy
L2501 HST
Aug 17, 2019
1,647
528
Benton City, WA
if you can get to the inner cable a coat of graphite would be good. If you can't take it apart it may be pre lubricated.
yamiacaveman
B3200 hst
Sep 16, 2023
Pa
That's one reason I asked this questioned I didn't know if they were prelubed or even needed to be lubed.
Thanks!
3,513
Petroleum Jelly (Vaseline) is used by most speedo-cable mfr’s.
3,719
Mine was replaced under warranty.
I did not do anything to it. Maybe I should have, but they are not that expensive so lets see how long this one works.
I did however, "clip" the zip-tie that they put on it to increase the bend radius.
That zip-tie, IMHO, makes too much of a sharp bend in the cable.
Not sure how yours is routed though.
I would be willing to bet "dollars to doughnuts" that a factory tech, just slaps it on, as is....just a feeling though......
