Okay so I Knew that this fix wouldn’t go smooth but now what??? I have a B5000 that someone tried to repair the #1 input shaft for the gear box by welding the shaft together without taking the tractor apart. And now pukes oil out because of the damage done to the seal. Ok so just replace the shaft, is what I thought and now doing BUT the catch is that the welds on this are horrendous!!! And are to massive to slide through the opening for the shaft to fit through. And I can’t get the cover plate off to get at the bits I need to get at. So any ideas on the best way to get this abomination cleaned up so this plate will come off for the new shaft??
