Swap an LA243 for an LA344
kupitz
BX2660 with LA243 FEL and Front mount BX2750 snowblower/2763A heated Curtis cab.
Mar 28, 2016
139
New Providence, PA
I searched and couldn't find any info, looking to swap out my existing loader for the LA344 SSQA style. Does anyone have an idea of cost and difficulty level for swapping out the hydraulics? I also have a BX2751QH with hydraulic attachments (broom, plow, blower) that I have to be able to connect after the swap.
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
134
138
Lakes Region, NH
Maybe you've already considered this, but I would be more concerned about possible difference in how the LA344 SSQA loader frame attaches to the tractor frame vs your existing LA243. The hydraulics should be the same 4 hoses, but perhaps with different style connectors. Have you considered simply adapting an SSQA adapter plate to your existing loader if your main reason for swapping loaders is to gain the SSQA?
kupitz
Mar 28, 2016
139
New Providence, PA
I have thought about that but there's a loader FS close to me that's cheaper than doing the mods to make mine SSQA. I thought the mounting frame was the same for both loaders? If it isn't then I wouldn't want to do the swap.
bobnic
Mar 7, 2025
134
138
Lakes Region, NH
I don't know if there is a difference in how the more recent loader mounts to the tractor frame, but since the LA344 loader came out for a more recent tractor series than yours, it is possible that the frame mounting is different. Just something I would check before purchasing.
edritchey
2026 Kubota ZD1211L-3-72, 2025 New Holland CNH WM75, Landmaster L5W UTV
Jul 19, 2014
1,193
969
Wellsville, PA
Seems like it would be easier to just get a newer BX that already has the LA344 on it.
11,282
I'm pretty sure it would be a direct swap as they take the same mounts.
Speed25
L2501(sold) - BX25D
Apr 23, 2024
350
536
NC
Yup, same frame on both tractors, so it should fit right in. The 344 probably has the flat face hydraulic connector, so you'd probably want to convert those to use your existing hoses. The flat face connector is known to leak and there are a number of threads around here on how to swap out your hoses/connectors. Maybe you'd get lucky and can just take the hoses off your old loader and swap them over.
Worst case scenario, just swap the parts from the end of the loader arms and use the SSQA/bucket from the new one on your old loader. Your quick hitch shouldn't be affected by the new loader since it mounts the same.
Ping
BX2370-1
Dec 25, 2018
374
401
Troy, Ohio
Why not just buy the SSQA adapter off a LA344? There was a recent thread about this but, from what I remember, they both use the same loader pin locations.
Regards
Speed25
L2501(sold) - BX25D
Apr 23, 2024
350
536
NC
Regards
Agreed, though you'd need a new bucket as well. Pretty sure the adapter is the BX2410 for $600 or so.
Edit:New SSQA buckets don't appear to be available at the dealerships for some reason.
Bearcatrp
Oversized Garden Tractor (aka BX1880) with loader, mower and 3 point
Mar 28, 2023
1,396
1,013
Minnesota
Why not take your tractor over to the seller to see if will mount. But, I would be worried about extra weight on the frame doing loader work. Would think Kubota engineers designed these loaders to match the tractor frame.
11,282
The LA344 is used on tractors from the BX1880 to BX23S so it's not an issue of his tractor "handling" it.
Bearcatrp
Mar 28, 2023
1,396
1,013
Minnesota
Thats provided the frame is the same thickness. Doesn't hurt to shoot off a email to kubota just to see what they say.
