Svl95-2s injection pump gear teeth angled wrong way.
rabtech
L3901HST
Jan 15, 2022
15
Haleyville AL
I dont see anything in that label that helps. It looks like they just put the cover of the original engine on it. Which doesnt help at all.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
586
251
CNY
This is the configuration I have in my V3800 manual, But I suspect is may be a newer variant. You are best served by contacting your Kubota industrial dealer to verify what should be in that engine.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
586
251
CNY
Also get the stamped sn off the LF side of the block where @whitetiger indicated to get the correct engine sn.
That is as long as no one has messed around and swapped things.
DrankTheOrangeKoolaid
M6800/M920, Case 780B
Sep 24, 2019
109
36
Alberta
If you have room to reach in with a piece of paper and a pencil, I've had success with that old trick when I couldn't get a decent picture.
rabtech
L3901HST
Jan 15, 2022
15
Haleyville AL
I have decoded the number. But it still does not help.
Its a 2 that is faded.
So the number is V3800 - T - 2FW0187
This breaks down as 2 = V3 F=2015 W=November and 0187 = a sequence number.
How do I order parts from that number ??
rabtech
L3901HST
Jan 15, 2022
15
Haleyville AL
Ok. So even Kabota has no idea what engine this is. But nevermind that. I have made some changes and I have fixed the original issue that caused all this mess. I just need to know if I have this these gears in time. Im 99% sure I do.
20260207_161156.jpg 20260207_161213.jpg 20260207_161208.jpg 20260207_154956.jpg
11,116
It is quite the oddity, I looked in every book and online source I have available, and no one lists those gears any differently.
I don't like the way 1 and 4 line up, but it might just be the camera angle.
besides that, yes they should be in time.
I take it your going to run it with the busted up gears?
It would be wiser to change all the gears to a standard set, I posted a link that set and they were pretty reasonable.
