Started this morning wanting to run a new wire for an hvac unit I just installed. That turned into a issue because the guys who installed the new hvac unit in the house before we bought it took up the only way to the crawl space with access to the electric panel I need to get to. So I said screw it I need to cut the duct so I’ll put it off until I get a coupling. I’ve had a wet spot in my yard and decided to investigate, we are on city sewer so I figured it was just a busted pipe and I’d dig it up and repair it. Found a pipe underground with a shovel and it appeared full of water and was actually broken. So I see some more dented areas in the lawn and decide to grab the backhoe and fix the rest of the broken parts. Well that’s when the day turned to shit, literally. Turns out the other parts were a leach field and the pipe that was broken isn’t doing anything, maybe an old pipe. Found the septic tank by accident, luckily didn’t damage it but broke a leach field perf pipe. Went to find the other end and there isn’t one it must of stopped right where I broke it, it appeared spliced and a clean break so I couldn’t take that for an answer until I dug enough to say there is actually not another end to connect to. I took tomorrow off to try to get everything sorted out but the really crappy thing is when we bought the house 3 years ago it was listed as city water and sewer. Never even thought there was a remote chance we were in a septic. Anyways wanted to vent now I’m just rambling. Here’s a photo of the disaster as it sits. Going to try to get it sorted out tomorrow hopefully.
