During my moderate overhaul of my tractor, I worked on the steering issue as there was some play. After reading about how problematic these steering boxes are, I decided to do some PM. I was surprised to see that there were NO oil coming out of the drain when I started it! Turns out after taking it apart, this is what I saw inside it...
The rest of the parts...
And a closeup of the nut ball...
If you'll notice, there's the chewed-up washer/ring thingamabob. Any idea where that could be from? I'm already ordering a bunch of replacement seals, bearings, shims, bushings, seals, etc. I'll be washing all this stuff off to get it back together the right way and use gear oil as specified. I don't have a parts washer so I'm gonna get a small one that holds 3.5 gallons. I wonder what solvent I can use to wash it with, especially with all that grease provided I get the bulk of it off?
Also, here's my mystery and I hope you'll assist. I've found these two, one at the bottom of the box, and one on the bottom of the shaft. I simply lost track of how they should be found, partly because it was just full of this grease.
I'm going to clean it out before I ask any further questions about the proper assembly. The parts diagram isn't too clear on orientation of the bearings but hopefully I'll learn after cleaning it and by reading the articles.
When it comes time to clean it all, The scary part is the nut ball assembly. I'd imagine that I'll have to take apart the whole thing and assemble it back together, carefully I'd imagine, and inside a box/pan with a magnet to keep the balls from rolling away.
