I am having trouble starting my Kubota G6200...I have replaced battery and starter. The glow plug indicator does light up but just wont start. It turns over. What am I missing here?
Start with the simple things. Is there fuel in the tank? Is the fuel shut off valve open? When was the last time the fuel filter was changed. Have you checked for fuel flow to the injection pump? Fuel to the injectors? Is there any smoke out of the exhaust while cranking the engine over?
If it has the electric fuel cut off solenoid, is it clicking when you turn the key just to the run position? Crack an injector line and crank the engine to see if you have fuel.
