On vacation for 2 weeks in Caribbean. Allot of minus temps at home. I usually do 10 seconds on glow plugs when cold but should I do it twice before trying to start? Thanks
independent testing up here in Canada says cold weather saps 40% of battery range from electric vehicles. Starting batteries similar.get a battery warmer too !!! Cold batteries don't have 100% juice to both spin and power .
rrr..rr.r.....![]()
Ten seconds is not enough in just about any temperature at which glow plugs are needed.On vacation for 2 weeks in Caribbean. Allot of minus temps at home. I usually do 10 seconds on glow plugs when cold but should I do it twice before trying to start? Thanks
Bingo.get a battery warmer too !!! Cold batteries don't have 100% juice to both spin and power .
rrr..rr.r.....![]()
Kubota should have extended that table downwards a few more rows. We're still having some -20°F and lower mornings here this February!!I would follow your manual but like others have said a little more will not hurt anything if battery etc... all in good condition.
^^^^^Ten seconds is not enough in just about any temperature at which glow plugs are needed.
I've held glow plugs on for over a minute before at zero or below.
Not uncommon for older Kubota engines to need glow plugs at 50 F.
I do use that stuff. Never an issue when I had my rig. I trust this stuff.Don't forget to add a diesel fuel additive that prevents gelling of the fuel. I use Power Service in the white bottle. I just give the tank a splash every time I add fuel. I know that I am using more than it says on the directions, but it works and I have never had a problem starting my tractor, no matter how cold it is outside. My tractor lives outside and it needs to start when I need it to.
Great post!lots of great advice for cold weather starting.
And for the less experienced cold warriors out their its important to remember lots of these little gems are ADDITIVE in nature when helping us start in cold weather. In warm weather not being in great condition on only 1 or 2 of these may never be noticed. At -30 though you probably have to get them all close to right for success!
At least good and pref. great condition on all of these really helps. Miss one or a few and no start mondays might be in our future.
- A good conditioned battery thats is warm
- functioning block heater
- functioning glow plugs
- seasonally specific and properly treated fuel
- clean and tight battery cables not only at the battery but starter, grounds, etc... help
- stored indoor helps
- clean air filter helps
- seasonally specific oil helps ( 10w engine oil at -30 is really thick and dirty makes it worse)
- stored out of the wind
- etc...
so good enough in summer maybe nowhere close enough for good enough in winter! being weak on just a couple of maintenance items can mean a no start in cold weather.
