Tractor 8 years old. It wanted to sputter on or after slope. The fuel line is clogged. I removed the fuel line as it enters the first filter. A trickle was coming through. I blew some air through. Viola. Problem fixed. It may happen again, but I know what to do. Working fine.
You have to remove a bracket that protects the line. Four 14 mm bolts. Remove 3 and loosen one. A little messy but easy. Hope it helps.
