SSV 65 Hydraulic Brake Release Not working
007Rancher
Eagle Mountain Utah
I've got an SSV 65 with about 100 hours on it. It has worked flawlessly until This afternoon. I had used it all morning moving feeds and such. I hopped in this afternoon fired it up and when to release the parking brake/hydraulic release button and nothing. Arm rests were down, and I was sitting in the seat. There are no error codes or anything. Could it be a bad switch, or am I missing something? everything appears to be plugged in correctly.
5,182
sounds like it could be a safety switch, check all fuses and try moving all interlocks one at a time, several times each to see if one is holding it up.
You next best step is to get the WSM for the unit, it should point you to what to test. ;)
