SSQA mod
pokey1416
Jun 24, 2020
564
835
SW Michigan
I’m liking the solid flat stock option. Pinned at both levers there’s no way they can move. Bolt or weld a scabbard on each implement and you should be set.
FYI I can verify that the stop block works. Bolt hitting it keeps pins from retracting further and dropping your attachment. That’s solved!
MSG H
L3901 HST RETIRED MIL.
Dec 20, 2020
45
20
VA
The stop block should fix the pin issue on the QA provided the pin tips don’t fail. Would be a Mod to QA if the stops are not present.
QA Handle
Cut a section of flat bar stock of equal thickness the length from outside to outside of the QA handles (about 6“ past where your hand would grab on each side)
Weld or bolt one side of the flat stock bar to the opposite side you would go to first, the two hitch pins go on your first pick side. Do you stand in front of the bucket, tractor parked? To the side?
I like the two pin setup, because if there’s too much upward movement between the two new arms we accomplished nothing here.
This would only lock the handles down. Any attempt to raise them when locked together would bend the arms or pivot points. By this point the branch should be obvious.
nbryan
Jan 3, 2019
1,253
786
Hadashville, Manitoba, Canada
QA Handle
Cut a section of flat bar stock of equal thickness the length from outside to outside of the QA handles (about 6 in past where your hand would grab on each side)
Sounds good, I'm just not going to lengthen the levers solidly (welded) because it will strike against the upper area of the back of my pallet forks frame when trying to scoop it with the quick attach.
MSG H
Dec 20, 2020
45
20
VA
Check post 22, second picture
nbryan
Jan 3, 2019
1,253
786
Saw the pictures. Is there something there for me to note? Looks more or less like how my ssqa fits both my bucket and forks. My forks are Martatch, differently shaped. When the ssqa levers are up, for hook up, and the ssqa is curled down a bit for better access to the top slot on the forks, the levers' top tip will often contact the pallet forks frame and nudge it down a bit before I can hook in fully. I often have to curl back a bit and get myself down there again to raise the lever up fully so the pin doesn't interfere with hooking properly.
Other's tractor/forks/ssqa/loader combo may not encounter the lever nudging "issue".
So definitely not looking to lengthen the levers in a solid (welded) way. A steel bar pivoting on a bolt through the end of one lever, which can hook to the opposite lever with a linch pin and lock it down, is the direction I'm going now.
xrocketengineer
Nov 14, 2020
764
677
Merritt Island, Florida
I am glad you guys have it all figured out. I have created enough hate and discontent ...
My job here is done! 😂
pokey1416
Jun 24, 2020
564
835
SW Michigan
This thread has been great. Please post pics when you’re done.
Happy New Year everyone!
nbryan
Jan 3, 2019
1,253
786
I'm digging around in the hardware disaster zone in my garage today for some parts to try an idea for this.
All I can say is, so far, there's one 15" metal bar or angle, 6 x 3/8" holes to drill, 3 x 3/8" machine bolts/washers/nuts, and a linch pin involved.
Wish me luck! It's a REAL mess in there - years of carpentry contracting bits and pieces piled up. But time for this stuff seems a-plenty lately...
More pics will definitely follow once more progress is made. Won't be long. I want something in place if possible before the next bush-push for firewood.
And Happy New Year too, to you and everyone!
nbryan
Jan 3, 2019
1,253
786
Done.
Those are 1/2" bolts. They're what I had around.
I figured out the concept and action with a piece of wood for a template, then just made do with "junk".
Ugly but effective!
I heaved on it heavily to check for play and there's very little, and what play there is still keeps those pins back inside their head stopper so I'll trust that a stick will break or bend first.
pokey1416
Jun 24, 2020
564
835
SW Michigan
Perfect solution. Can't see those going anywhere. Keep us posted on how they work.
xrocketengineer
Nov 14, 2020
764
677
Done.
Ugly but effective!
Great design, simple and functional. Get a patent on it!
nbryan
Jan 3, 2019
1,253
786
Thanks!
Got no thousands of $ to hire some patent lawyers. OTT knows what I designed and built!
Some machinist and welder types can refine the design, spray paint it orange etc. Be fun to see if anything more refined comes to light.
Really, if someone copies and patents, I'm not in a position to stop it. No $or time for stuff like that. Just have enough $ to fuel and maintain the steed, and the time to go gather tamarack firewood, now without the ssqa lever releasing worry.
nbryan
Jan 3, 2019
1,253
786
Welded a length of chain to the levers with a small carabiner snap hook to prevent inadvertent opening of the latches from sticks, etc. Will thread the chain through a piece of silastic tubing so the paint doesn't get rubbed through. Picture was taken with the bucket hyper-extended in the dump position.
That'll work!
nbryan
Jan 3, 2019
1,253
786
Seat Switch is required by Outdoor Power Equipment Safety standards that cover a LOT of countries. Don't have a choice, from the smallest garden tractor to ANY tractor than can be fallen off of or turned over. That standard pretty much includes ALL tractors and a lot of other equipment too. If the safety being completely mechanical is a need, I guess you could tie a string to the coil wire if you had a gasser. But since there's no ignition system on a diesel, that's a little harder to do with a string, but I guess you could still come up with a butterfly in the intake that would shut off air flow.
The seat switch is to shut the engine down if the operator leaves the seat and the transmission is engaged, or the PTO. Kubota has been generous enough to provide a new option on the LX models that allows operating the PTO with the seat still down by locking the brake, putting the range selector in N, and then pushing an override button for about 10 seconds. This allows using stationary equipment like chippers. Miss one detail, you shut the engine down. Simple safety. It works.
But back to the subject at hand, I'm not quite sure that a chain that heavy would be required, and I'd probably opt for some kind of pin latch if I was that worried about it coming out. If 'sticks' come up behind that adapter plate, stiff enough to operate those levers, you're about to either rip a front tire apart or relocate your radiator to the 3 point hitch. As someone else pointed out, they latch by cam action over center and are spring loaded. On top of that, you didn't pin the actual latches, only the handles. You did know those handles can be fully engaged and the latch still not fully engaged, right? What's to stop the same 'stick' from pushing the latch pin out of it's hole? The latch pins not fully engaging is more often than not what creates hazards, despite the handles being fully down. There's no substitute for a visual confirmation that the latch pins are fully engaged. So, chaining the operating handles really isn't going to help much to prevent the problem you're targeting.
To each his own, though. Not criticizing, just debating.
With the handles fully down the pins are blocked from rising more than about 1/2". Please see previous posts and photos (post #50, pic #1). Raise a locking lever 2" (to about horizontal) and the pin is pulled out from under the stop block, and can rise further if pushed from below, but still is not fully clear or the fork frame. But enough to fully compress the pin spring.
I ALWAYS visually confirm that the pins have engaged when attaching. As should any operator using ssqa.
And I twisted my ssqa frame when a not-too-large branch flipped a lever up while backing up, and the forks frame on that side caught a stump. A heavier lever resistance would have either bent or broken that tree sapling or I would have noticed being hung up on it.
So with my contraption there'll be no more unintended or unnoticed lever release.
nbryan
Jan 3, 2019
1,253
786
My SSQA lever lock has performed flawlessly so far. And I've certainly given it reason to let go - had some pretty thick branches jammed up in there last week while trail breaking in the back 80.
It's a keeper!
5,083
Drill a hole in the end of each handle.
Get a strong bungee cord (about 18"-2')
Put one end in the hole at the end of the handle,
Wrap the bungee around the bar of the front loader QA plate.
Put the other end into the end of the other handle.
Easy peasy.
I still want a kit to automate/power mine.
My latches ARE hydraulically operated/latched.
My L48 TLB came to me (I bought from orig. owner) with that hyd. latching system.
I absolutely love it! ( I am just too old to enjoy climbing on and off the tractor).
From the installation, it looks to me that it may not have been a "kit", but rather a system that the selling dealer had mfg'd. by a 3rd party.
I think the work may have been done by a shop over in Maine
The tractor dealer was Union Farm Equipment in Union, ME., but I believe they may have subbed out the hyd. thumb and latches to MC Faulkner.
Shop was likely MC Faulkner of Buxton, ME., but they have since been bought out by: SRS Attachments, of Norridgewock, ME.
207-858-0690
The system is really a very simple concept, with one small cylinder, and using a diverter as a hyd. power source.
I cannot send pictures, because I am 1,500 miles away.
