I have a 200 gal. tank on a trailer and want to use it to spray a field. It has a fan broadcast nozzle and a wand with some hose.
I have this manifold and not sure how to plumb it. I'm thinking the pump discharge goes in the end opposite the regulator. Discharge to the spray nozzle goes to the connection closest to the regulator. If so, do I put a tee in that line with a valve to go to a spray wand? Then does the connection nearest the gauge a re-circulation line back to the tank? Thanks for a lesson in plumbing!!!
