spool detent bearing holder
wpcmj
b2100
Aug 17, 2025
saskatchewan
Hi all i have read just about everything on the repair of the hydralic control valve. I have a valve get stuck this was a no brainer debris in the valve boom on la301 wont lower and float wont work . Problem rust in detent. Solution took cap off removed detent bearings and spring and collar (this was in rough shape) cleaned caps and added drain holes as ther is none. Put back together works but no float function as expected .
I can get new repair kit. The valve is the husco 9210 2 spool with float .
My question is there an easy way to take the float bearing holder off the end of the spool shaft , this appears to be threaded in and i didnt want to pull spool shaft out if I didn't have to.
Thanks
9,153
You don't have to take the spool valve out to remove it, just hold the top of the spool from spinning when removing it.
wpcmj
b2100
Aug 17, 2025
saskatchewan
Ok tried that but didn't want to damage any thing
Just did not move. Di you really does it turn click wise or counter clock wise. And is there any special tool I need
9,153
No special tool, it's probably has some loctite on it and will need a little convincing.
Should be normal threads. ;)
