Speed sensor
AllDodge
M9540 RTV1100
Jan 19, 2019
191
South Central, ky
Haven't found the sensor yet, but will look further tomorrow. While looking for it I found that all 4 of the bolts (item 150) holding bracket (item 110) are loose. Have some rust on the threads. Appears someone had removed the bracket for something (maybe speed sensor) and forgot to tighten them back down
AllDodge
M9540 RTV1100
Jan 19, 2019
191
South Central, ky
Found the sensor and it is plugged in. Tried to unplug and replug, but no luck. Maybe there is a connector with a damaged pin, or cut wire going to the speed sensor.
Did find some kind of gasket sealer between the rear axle and transmission, so appears this tractor was split in half to fix something.
Anyone able to look into the dealer data base and determine if anything was listed?
Will get the serial number if someone can
AllDodge
M9540 RTV1100
Jan 19, 2019
191
South Central, ky
Dealer says the tractor got a new radiator assy at 184 hours, and that was the only thing showing. So other work was done by someone else
5,342
Does the WSM tell you how to test the sensor?
