kubotasam
Kubota front blade KUFD110 designed to fit B7100 & B6100. It is in good overall shape. I do not have the subframe. If you have a B7100 with a B219 loader the subframe from the loader will work with a little welding.
Blade comes with control valve and hoses with quick disconnects. This has down pressure for pushing dirt and a float position for plowing snow. Also power angle. This is an extremely well built blade and it is strong enough that it could be widened so that it could be adapted to a somewhat larger tractor. The blade can be locked with pins so it will not spring forward when being used for dirt.
Asking $350.00
If you want this for a B7100 I will sell a hydraulic tap in block with the blade for an additional $75.00
Asking $350.00
