Snowblower
ravensview
bx23slb
Nov 18, 2019
67
14
U.P.,MI,USA
Where are you in the UP? I’m in 5 miles south of big bay. My biggest reason for the front blower is my wife will be doing the snow blowing a lot when I’m out of town. She said no snowblower unless it’s up front. Kind of hard to argue with here lol.
Yep, that’s an argument that is un winnable, Alger/Marquette snow line, it will be snowing like a banshee out and I head into MQT, and it’s bright and sunny out, but I do try to limit my trips there, it’s just to dang busy
Welder08
L3560
Jun 10, 2020
15
UP of michigan
Yep, that’s an argument that is un winnable, Skandia, Alger/Marquette snow line, it will be snowing like a banshee out and I head into MQT, and it’s bright and sunny out, but I do try to limit my trips there, it’s just to dang busy
You guys get dumped on out that way. We get moderate snow here. Can go either way really
SidecarFlip
Banned
557
One nice aspect of retirement is, snow removal in the winter for me is totally optional as I don't 'have' to go anywhere unless I want to. I can sit in front of the fire and watch it snow and don't have to go out in it.
I not so fondly remember the days of getting up at 4am and getting the road cleared to the pavement so I could get to work at 8am. Now, I just kick back and listen to the scanner and tune into all the police calls for assistance in fender benders.
Welder08
L3560
Jun 10, 2020
15
UP of michigan
Sounds nice. I’ve got a few years before I can do that.
eiresurg
79
15
Central, MN
I have the L4469 on my L3560HSTC in Northern Minnesota and it's the perfect size. I've cleared 18" of wet snow, no problem. I think the L4479 would be fine, but it may bog down with the heavier stuff. Why not get the L4469? It's probably a little cheaper and still wide enough to cover your tracks.
As for front vs rear mount, I'd never consider a rear-mount at this point. If you can afford the front mount, get that. The only draw-back is mounting and dismounting the sub-frame. I find it to be a royal pain. If you plan to take the blower on and off so you can use other implements in the winter, this could become a real nuisance. If the only function this tractor will have in the winter is blowing snow, then this won't be an issue for you.
Welder08
L3560
Jun 10, 2020
15
UP of michigan
By the looks of it I will be going the 4469 route. The blower will stay on all winter. According to my measurements the 64” will be slightly narrower than the tractor. They are going to put wing extensions on to combat this.
200mph
Mar 3, 2017
1,228
61
PA
With respect to snowblower width... Having a blower as wide as the outside tires is OK when going straight, but becomes an issue when turning. When turning the rear tires will not track within the cleared pathway and will be forced to try and run over the unblown snow. In deep snow falls this can cause some problems.
I've used a L3130 with 6' front blower, that everyone will say is way underpowered and I agree. However this can be compensated for by slowing down. My technique is to monitor engine RPM and keep ground speed at a point where the RPM's remain high. Yes it is slower, with less HP, but having the rear tires trying to run over unblown snow can become an issue when turning on steep driveways. I've since moved up in HP with the L4740, but the rear tire width is much wider, so I made a set of extensions. Still using the same technique for ground speed.
Welder08
L3560
Jun 10, 2020
15
UP of michigan
They plan on putting extensions in the blower to help this issue.
eiresurg
79
15
Central, MN
You're going to love the L4469! It's a beast! Clearing snow has never been so much fun. In addition to 300 yards of driveway, I also had to clear a half-mile of road on several occasions where we got big dumps of snow and the township hadn't gotten to us in a timely manner. I too have the "wings" on mine. Haven't had a problem with the track width vs blower width. As long as you don't have to make any real tight turns, it shouldn't be a problem. Additionally, keep in mind that the subframe significantly reduces your clearance. I'd guess it's about 10" with the subframe. Not a problem with most driveways, but could be an issue in certain circumstances.
eiresurg
79
15
Central, MN
Thank you for the reply. It’s reasuring to hear you say that. Was the blowing distance good with all types of snow?
Easily launched all types of snow 30+ feet. Be careful pointing it at your house or other fragile structures or plants. One of the best purchases I've ever made. The hydraulic chute rotates 180 degrees (maybe a little more). I only wish I had a third function to adjust the elevation (up or down trajectory of the snow) of the chute. That has to be done manually. Most of my snowblowing was done at night and a good set of lights is essential. I plan to install an LED light bar before the upcoming winter. The stock lights are nearly useless.
Welder08
L3560
Jun 10, 2020
15
UP of michigan
I’ll be having the third function. I gotta make it easy for the wife!
Tim Horton
267
49
Lake Superior
We have an older 50" Allied Buhler Farm King 3pt blower..
Our tractor would handle a bigger blower, but that would have required more $ for a bigger blower..
The one we have works well, was available close by, was quite reasonable priced... All considered a combo of features I like..
eiresurg
79
15
Central, MN
You may want to try it without the third function to avoid the extra expense. I have never had to adjust the chute elevation. Depending on your scenario, there may be circumstances where you would need to, but it just hasn't been the case for me. Easy to add on later if you need to. In addition to adding better front an rear lights, I'd highly recommend some form of rear ballast. I have my tire filled and that worked great last winter. When blowing heavy, deep snow, the machine can take on a mind of it's own if you're not careful and slip you into a ditch. So, if any part of your driveway has a ditch, you need to be careful there. The ballast will help with limiting the effect of that. Also, I usually put the blower on "float" and this tends to increase the chances of the effect. In a tricky spot, I've found that taking it off "float" and just skimming the surface gives better control.
