Snowblower impeller shear pins keep breaking
2,097
That makes it sound like the impeller shaft/bearings or space between rotating and stationary parts is changing.
And the grade 8 bolts are stronger but more brittle than grade 5 so they may be cracking and failing due to small impacts. I would use grade 5 and see if they are better. Also check the shape of the hole as suggested earlier.
Kubota BX 1860
BX 1860, oops, traded it for a BX2370
Jun 23, 2011
81
Raymond, ME
I'm sure you know this, but I have to mention it because nobody else has. Don't crank down hard on the shear bolts when installing them, as the stress from tightening will make them break that much quicker. They use lock nuts so in my case I just tighten them until they make contact with the impeller or augur and call it good. I broke shear pins constantly with an Ariens walk-behind until the dealer told me this little tip.
conropl
L3560 HSDC
Oct 17, 2016
233
West Michigan
Great point.
Sent from my SM-J737V using Tapatalk
B2650man
B2650
Dec 30, 2018
10
Newfoundland Canada
Problem solved and thanks again for your help.
I have been given the incorrect grade shear pins ( for several years ) for the impeller. I have been using #8 pins and not the correctly specified grade 5 pins. As the grade 8 pins are slightly smaller, they did not seat well in the pin holes and over time the play in the hole caused the edges of the pin holes to become oblong and "egged out" . See attached pic. This has only further aggravated the problem and now the grade 8 pins are failing at an even faster rate. I now need to repair / replace the plates on the snowblower.
I tried the correct pin this morning and viola, problem solved! And I no longer need to maintain a low throttle speed so my chute is less likely to clog.
Thanks again. Let it snow !
NoJacketRequired
May 25, 2016
431
71
Ottawa, Ontario
Further to ... a few years back I had problems with this same blower and it was determined that the chain was incorrectly installed during the original assembly. The unit had to be taken apart and reassembled by the dealer. Not sure if this may have corrupted the unit internally but clearly something must be wrong with the mechanics if I cannot operate at high throttle speeds without continually breaking the impeller pins.
At this point I may investigate reaming out the impeller pin holes and installing a stronger bolt. I can't imagine this would damage the gearbox if I am only pushing light snow.
Cheers everyone !
A couple of thoughts...
1) I would suggest you do a "divide and conquer" method of troubleshooting. Pull the impeller sheer bolt out entirely. Pull the short driveshaft from the blower to the quick hitch entirely. This will leave you with just the impeller and chain reduction drive to spin independently of the augers and gear box.
Spin the impeller by hand. See if it's catching on anything, indicative of a bent impeller shaft. Feel the running tension on the drive chain. When I've done this I can feel the "click click click" of each chain link running across the teeth of the sprockets. Feel also for backlash or slack in the chain. There should be some. Given the size of the chain links themselves and the small distance between the sprocket centers there's very little option available to get the chain to fit perfectly - some slack will be present in the chain. There should not be enough slack to allow a chain link to have to rise up to climb onto the sprocket.
Spin the augers by hand and feel how they and the gearbox run - should be quite smooth. You'll feel some backlash between the two augers; that seems to be perfectly natural as I've felt it on all three of my blowers as well as on brand new ones at the Kubota dealers. If the gearbox is bound up then you should be looking there for the cause there. I highly doubt it would be so bound up as to break a shear bolt.
2) rather than trust the dealer, go to a fastener supplier and source the correct Grade 5 bolts to use as shear bolts. While the Kubota dealer is not likely providing the wrong part, we do know that shear bolts for the impeller should be grade 5, and we don't know for certain the grade of the part being provided by the dealer. Again, I don't intend to impugn your dealer but rather I am suggesting they are working with what they get from Kubota which may not always be the right part.
As I've been writing this I've come up with one other thought... There is a potential for you to have a bad input bearing on the impeller shaft. This would allow the rotational forces to escalate quite dramatically when under load. Again, with the shear bolt and input driveshaft removed, play around with the impeller to see if that input bearing has play in it.
And yet another thought... The chain sprockets are held onto their respective shafts with Woodruff keys and grub screws. Make sure those grub screws are tightened down and that you've actually got the Woodruff keys in place.
EDIT: It took me far too long to write the post above Clearly the OP has found the cause of the problem. The right part is critical to success!
KeithG
2000 Kubota B2710, Woods BH75 backhoe, LandPride York Rake, B2783 Snow Blower
Jan 1, 2016
129
Rindge, NH
I have the same front mounted snow blower and the manual/dealer stated that a "fully threaded" grade 8 bolt should be used for the impeller. It took a long time to identify this and I learned a lot about bolts used for shear protection when trying to identify the correct bolt. I created the following post (in this forum) to help everyone determine the correct shear bolt to use:
http://www.orangetractortalks.com/forums/showthread.php?t=23019
Happy reading, -Keith
