No doubt some of you have experienced the same issues the last few winters with the freeze-thaw cycle and if you have a gravel drive the skids digging in and the blower collecting and redistributing gravel where you don't want it.
So looking over YouTube I noticed some videos where people added a plastic tube to the bottom edge of both snowblowers and plows to stop the dig in.
I thought the plastic tube would be a bit light for a front-mounted blower and as I had some thick wall galv tube on hand and a few bits of scrap I decided to make something up.
It is quite simple, I am using existing holes the side where the skids attach and the bottom where the cutting edge fixes. I have kept the metal thickness the same as that used 3mm and have the tube about 12mm below the existing cutting edge.
The proof will be in the pudding but I thought now was the time to experiment.
I also made a set of wider skids to mount with the gravel deflector.
I Will post again when I mount it. Comments welcome
