Snowblower and Snow Pusher for L series, what width?
Matchmaker
L3410, L3210, L4740. M9000, KX080, RTV, z327
Jul 9, 2022
Ontario Canada
I just picked up a pair of L series tractors (L3210 and L4740) and want to add rear snowblowers front snow pusher/blades to both. What widths can they handle. I am north of Ottawa Canada and can get some fairly heavy snowfalls. I am looking for inverted models but don’t know if that makes a difference in performance and therefore width.
I should add that these two both came with R3 tire sets but will probably swap out to R1s.
mikester
M59 TLB
Oct 21, 2017
3,549
2,010
www.divergentstuff.ca
I wonder why road plow trucks weigh 60 tonnes to push a 10 foot plow?
I use a snowblower because plows suck when you have lots of snow to deal with.
4,908
You probably only want them a bit wider than the track(width) of your tires.
Too wide and you'll slowly chew more snow than you can blow,especially if it's 'high density' snow (aka wet and heavy ! ).
Also be sure to swap rear tires when you add the snowblowers.
animals45
L3301l
Apr 22, 2021
269
84
Mabie CA
Don't forget that you may need wheel spacers to allow for tire chains . You need to figure that out before you agree on what the width of your blowers will be .
animals45
ctfjr
L3800HST
Dec 7, 2009
1,879
2,293
central ct
I had a 60" Normand on my L3400 and now have a 60" Blizzard on my L3800. In doubt we get as much snow here (CT) as you do but we did have a 4' snow fall that the L3400 handled fine - slow but fine.
