Snow blower
Wayne64SS
'13 MX5100HST, '82 B7100HST
May 27, 2015
26
Duanesburg NY
that looks like the most inefficient snowblower ever. Might be worth unloading that one and get one a little newer.
10,226
Yes that style of blower takes a ton of HP to run, also require you to run it at max speed, it's a true blower, not a good design for a little tractor.
I have a 60" 3 point 2 stage made for compact tractors and while it worked on my B7100, it was too much for it, smaller and lighter is the key.
For now until you get a different blower, do you have a back blade you can use?
If not, get one, they are cheaper than a blower and work really well on these little tractors.
That tractor was very well suited for the Snow plows that were offered with them, that would be a good choice too.
7,186
Mark -
I don't travel much, know NOTHING about Colorado Springs.
You bought the tractor, etc. at an auction.
I'm from a rural area in upstate New York, and we often have spring/fall consignment equipment auctions. They usually have 3ph blowers - 4'-10'. They often bring little $$. Of course, some aren't worth much!!
Keep your eye out!;)
We get "lake effect" snow in our area off the Great Lakes. Thankfully we're on the edge of it - usually real light stuff when very cold with hard NW wind. That machine would move that light stuff. A 2-stage would move it better on your tractor.:D
markwelle
Mid-70's 7100d w/ FEL
Jun 28, 2015
Colorado Springs
Just a quick update:
Had another decent storm this week. About 12" of actual snow, with high winds blowing more drifts of 24-30". This time around I went out during the blizzard and cleared the drive before the drifts got over 18", and then did it again that night after the snow was done. The only other adjustments I made were:
1) Greasing the heck out of the interior of the blower to avoid clogging
2) I adjusted/rotated the 2 impellers so that they were perpendicular to one another - that way only 1 was trying to eject snow at a time.
What a difference!
I cut right through up to 18", full width bites, ejecting snow 25ft into the yard! PTO speed 1, reverse 1, in Lo gear. Slow and steady won this race for sure! Just chugged my way down the 50yds of driveway, never had to adjust the throttle, no slipping, no clogging, just snow flying!
So, I've learned to not let it pile up too high, don't wait too long and let it get wet and heavy, grease is my friend, and I can clear some serious snow!:D
08quadram
bx2350d; Taylor Way 48" tiller; Farm King 50" snow blower
Apr 28, 2014
289
strawberry point, ia
awesome, if you look at snow blowers they use on train tracks. they are one large spinning wheel.
glad it worked for you!
gssixgun
L3600, FEL, SnoBlower, Box Blade, Rear Blade, Forks, Cultivator, Plow
Jan 5, 2013
258
47
Sandpoint ID
www.gemstarcustoms.com
Hint until you decide to get a 2 stage blower :)
This Silicon stuff from Wally World REALLY makes a huge difference with moving wet snow through any blower
I tried it when I was running a L185 on the blower and it made a world of difference.. Now it is just an automatic any time I fire up the tractor to blow snow I spray the chute and impellers.. I also never let the wet stuff get over 6-8 inches deep before clearing it
I clear about 1 mile of drive and I haven't ever had to re-spray it...
http://www.walmart.com/ip/CNC-Heavy-Duty-Silicone-Lubricant/16817419
ps: CS/CO is my old hometown :)
flynavy
B7100 HST-D w/FEL,654 Whel Hrs w/blade, 2654 Hsqv mowr, 28h Cfstm snowblower&cab
May 1, 2014
95
Laurel Springs, NJ
They also make a non-stick paint for the chutes so snow doesn't stick. A little expensive BUT if it works ....well beats getting off and on to clear them.
I did mine this summer haven't tried it yet...
