Slow leaks?
Slowpoke500
Kubota L3302, loader, Grapple, bush hog
Jan 1, 2026
NC
I bought a new L3302. After about 70 hours one of the front tires lost pressure and separated from the rim. I aired it up and found that there was a very slight leak in a couple of places at the bead. I have to reinflate it every couple of days. About 15 hours later, the other side did the same thing. I’ll have to tube them. Just wondering if anyone else has this problem with Kubota compact factory B14 tires.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
4,032
2,484
WestTn/NoMs
Unless you've damaged the bead seal or rim, you shouldn't need tubes. Dismount the tires, clean and inspect the beads and wheels, and reinstall the tires if not damaged.
Sounds like you're not running enough pressure in the fronts. Also, assuming you're using a front loader, do you have ballast weight on the 3ph?
5,580
I am not normally a fan of adding stuff to tires, however, I did get some of that Kubota brand leak stopper and put it in my front tires.
I mainly put it in as a preventative thing, in case I picked up a nail or something.
Which puts me in a wierd spot......I can't say if it works or not, but I don't have any leaks????
They claim that it is "water soluble" so it is easily washed off, but it can prevent pretty big holes from leaking....
Might be worth a shot? 🤷‍♂️
EDIT: Way back "in the day", when I was a budding mechanic, I/we used a "black goo" that was applied with the brush (that was integral to the cans top)...It was specifically for bead leaks that would not seal.
I can see the can in my head, but can't remember the name brand of it. Worked great though.
That was 40 years ago, so I'm not sure if they still make it.
Caden
1979 B7100
Apr 16, 2026
351
196
Well if you ran it and it separated from the rim, then it would have been easy for some dirt of debris to get on the bead, therefore not making good seal until you clean it up.
A front tire needs sufficient air, otherwise the side load and pressure that comes with using a loader will be problematic for you.
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,483
676
Richmond, Virginia
This stuff... Liberally apply, air up, wait half an hour and wipe off the squeeze out.
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
1,228
1,117
Amsterdam, NY
I'm not even going to try and imagine what's in your head. o_O
They still make the stuff.
OntheRidge
Nov 1, 2020
503
591
It's new, make the dealer fix it.
BAP
Dec 31, 2012
3,207
1,320
Dealer will not fix a tire issue on a 70hr tractor for free. If the tire went flat right after it came off the delivery truck they might, but not after using it.
