Slow FEL and 3Ph
Jake9000
M9000DTC
Aug 4, 2025
Ny
I have a m9000 with about 3400 hours on it. Some reason the fel and the 3ph won’t raise without reving up the engine. I’m not sure where to start looking for issues.
5,345
Start by looking at the loader hydraulic connections to the tractor. Is this new behavior?
Jake9000
M9000DTC
Aug 4, 2025
Ny
I switched the dump/curl with the raise lower/quick connectors and there was no difference.
This tractor was just purchased this spring. I haven’t been able to use it hardly at all yet. The loader appeared to operate normally when purchased. It would raise at a good speed at idle.
5,345
Put it back.
Make sure ALL your rear remotes are in neutral. Dont rely on the levers - double check at the valves.
Jake9000
M9000DTC
Aug 4, 2025
Ny
Put it back.
loader hoses are in the proper locations. Both remotes are in neutral. I should add it also has a third function coming off of the loader valve.
