Simple front weight design 2.
volp
Kubota B6001, MF35 with backhoe, Ford 3000, JD LX186 Lawn tractor
The simple front weight design in my earlier thread worked but the front end was still not firmly placed on the ground with a heavy back load.
I went to the local iron merchant and bought two pieces of steel 400 mm long and 100 mm square each with a weight of 32 kilo (about 70 pound).
Welded a 180 mm long bit of L-shaped steel to the side as you can se below.
The other got the same steel on each corner sticking down 70 mm. Then a piece of rebar as handle to place it on the first weight. Hopefully 64 kilo is enought.
I have not painted it orange yet.:D
Anders
bmblank
Mar 4, 2015
756
464
Cadillac, MI
yeah, that oughta do it.
Sent from my XT1254 using Forum Fiend v1.3.2.
mendonsy
B7500HST/LA302
May 28, 2012
361
37
Mendon, NY
That design should work fine. I have had something similar (but smaller) on my old Case garden tractor for about 35 years.
4,786
Yes Sir that should keep the front end down real nice
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
Nice...
I might have to steal that if I have to remove my existing factory front weight... it's the LA524 weight set... :D
2,988
Volp,
I like what you did - I have been wanting to add weight to my B7100......thinking concrete, this gives me a new perspective on it !!! Excellent work.:)
Tooljunkie
May 13, 2014
4,150
34
Im guessing 70 kilos. Its 3 times the size of the previous steel block that was there.it made a big improvement, at least now no more wheelstands with my 60"finish mower.
volp
After returning to Mallorca this autumn I have finally put some colour on the front weights. I also put a piece of hose on the rebar handle to get a more comfortable grip. :D
One thing which is not in the picture is a strap to lock the weights so that they don't fall off in bumpy terrain! Do not ask how I found this out. :eek:
Anders
KRT
Thank you volp.
To answer your question, I work in a sheet metal shop so I have access to a lot of the technology for working metal including CNC turret presses, LASER's, press brakes, welding, powder coating, etc. When I need, or find an excuse to need something for the Kubota I try to design and fabricate it rather than purchase it. We built a rear blade/box blade a few months ago and the weight of it made the front end light so that created an excuse for front weights.
The weights were LASER cut from .250" thick steel and 5 of them are bolted together with the center one having the extended handle out of the top. Each set of 5 plates weighs approximately 26 pounds and the mount that we fabricated holds 10 sets. One long 1/2" bolt goes through all of them and keeps them tight.
Tooljunkie
May 13, 2014
4,150
34
Sorry,Volp vever saw question til now. J-hooks hold weights on securely. Need to countersink holes so nuts are flush with top surface. The contact hood when i open it.
4,786
KRT, do you use a plow of blower on that tractor, if so how much clearance dose that set up give or do you have to remove the whole thing
KRT
Skeets, I do not have a blower and just purchased the Kubota in June. My current intention is to utilize the rear blade for snow removal. The front weights were designed to match the ground clearance of the front axle.
In the picture the rear blade is set up as my version of a box blade to level the gravel drive. For winter I intend to remove the sides and utilize the casters on the blade to keep the gravel in the drive and not in the yard.
If your clearance question was in regards to the rear blade, it is not currently installed but I would be happy to measure and answer you when it is on.
