Sickle bar mower suggestion
southernboy
Kubota L2501 4WD HST, LA525 Loader, Land Pride RCR1260 Cutter, Land Pride BB1260
Jul 25, 2018
Boaz, Alabama
Hi all, I’m new to the site, been lurking for awhile, great source of information. I’m in need of a sickle bar mower for my Kubota L2501. I’ve been researching and read that there may be issues hooking tho old mowers to a modern compact tractor, narrow wheel width and such. I would prefer a 5 or 6 foot model, any suggestions would be appreciated. Thanks
russell.still.5
197
Lafayette, Alabama
I have a NH 451 that has been very reliable through the years. Not sure how f it would fit an L series or not. I had to do some modification to get it to fit my M Series.
southernboy
Jul 25, 2018
Boaz, Alabama
I found a NH 451 on Craigslist for $700, it’s a 7 footer. I may go check it out but I was really wanting a shorter one.
russell.still.5
197
Lafayette, Alabama
Before you buy it I would make sure it would fit the tractor. They were designed for the old school tractors not today’s compacts. KEEP PLENTY IF GREASE IN THE WOBBLE DRIVE. A lot of expensive bearings in there. But like I said I have never ha an issue.
russell.still.5
197
Lafayette, Alabama
I think I saw the same one. It looks like it is missing the lift mechanism. It’s a big u shaped bar that hooks to the top link pin and then the top link goes between it and the mower. It moves a cable to pick up the cutter bar when you lift the mower with the 3 point hitch.
SDT
multiple and various
Apr 15, 2018
3,250
1,041
SE, IN
The 451 is a very good sickle bar mower but not suited to your CUT.
It will interfere with the tires and, likely, other things.
Not sure that you will find a small used sickle bar mower that will mount to your CUT without modifications.
Back in the day, most small sickle bar mowers were belly mounted.
SDT
Sammy3700
L3800HST,524Loader,BH77,Landplane,Disk,Mowers and more
Feb 20, 2012
437
41
Red Springs, NC
Also look at a case ih 1300 if you can find one. I have one and will mow straight up to straight down. Hooks to 3pt and pro only!! It was made in 1995
majorwager
MX5100 FEL ford 1620 FEL International 484 FEL Lull 844C
I have a NH 451, and use it behind my compact 1620 ford, 22 pto hp
It has the 9 ft cutting bar and it does not, NOT conflict w/ tires or linkage.
There is a small steel adapter required that extends the factory linkage slightly rearward . It is a NH part, made specifically for use w/ compact tractors.
I bought this mower new in the 1990's and NH realized it would be adapted to compact tractors.
If interested, I'll look in my owner's manual for the adapter part #.
southernboy
Jul 25, 2018
Boaz, Alabama
Thanks all for the info, I need it to cut hay , I bought a mini round baler and rake now I just need a cutter. The NH I was looking at was sold , so I’m still looking.
southernboy
Jul 25, 2018
Boaz, Alabama
southernboy
Jul 25, 2018
Boaz, Alabama
Can you send me that part number? Thanks
southernboy
Jul 25, 2018
Boaz, Alabama
Just an update, I picked up a NH 450 today. I didn’t have time to attempt to connect it to my tractor, I’ll try tomorrow, fingers crossed. But I was wondering if anyone had an owners manual they would like to share, PDF version. Thanks
