Titan17
L3901 TLB, Caroni RFM, Scag Wildcat ZTR, Piranha TB,York RE 96", MTL HD 48" grap
B1750 gear drive with 640 original hours. Bought this tractor recently from a friend. Hours are correct but hyd. Oil never changed or screen never cleaned.
Tractor is loosing hyd. pressure both at the loader valve and the hydraulic block (1500 psi when cold drops to 500psi when hot). Needless to say nothing is working correctly.
I inspected pressure relief in hydraulic block and loader valve, replaced O rings, confirmed both reliefs are not contaminated.
I'm waiting on components (BSP banjo bolt and adapter, manual needle valve for fluid bypass) so that I can isolate just the pump for an accurate pressure test.
I figured I would dismantle pump in the meantime to replace rotary seal and look for anything abnormal inside. I'm posting pictures. Doesn't look good to me but another opinion would be helpful. Most notable are the bronze end plates being scored.
Again the filter screen was badly clogged and the hydraulic oil runs very hot
I will probably buy a new aftermarket pump from Legacy Hydraulics and a new loader spool valve from Summit.
The pump is a left hand from what I gather..
Any other recommendations on loader valve and pump?? OEM is out of the question because on price. I will turn this into a strictly mowing tractor before I spend that much $$$
