Since this is sort of a separate topic from the rebuilding the L345DT engine, I thought I would make it a separate thread.
Today, I thought I'd simply take the dual stage clutch, discs, and flywheel to the Kubota dealer and save myself a lot of heartache by having them use their special tool (Code No. 07916-90050) and have the clutch clearance set prior to mounting the flywheel and dual clutch onto the engine. Refer to the pdf below for the manual direction. Small wrinkle...they do not have the clutch tool.
They suggested I talk to JD and New Holland. They both had a tool for setting up dual stage clutches but were doubtful if they had the right "fingers" or "sleeve" for setting the Kubota. I got a look at the NH tool and it is quite a bit different with an arm that serves as a "throw out bearing" and you adjust from that down to the bolts.
Not to be completely stumped, I just knew I could turn to the geniuses and shade tree mechs hereabouts for their advice and work arounds on how they have accomplished similar tasks of setting the clearances. I have searched here within and Googled to come up with a technique and thus far have not come up with an answer.
Secondly, it seems that I should be able to use my clutch alignment tool that will work for the pilot bearing and outer plate, but I will need to add a middle improvised section to center the first plate. In affect, this would be like a rod with three diameters (pilot, first plate, and second plate). Sound reasonable?
