Anyone ever make a septic-drain-field repair? Mine is 25 yrs old and become “sluggish” due to small roots that have managed to plug all the holes in the plastic 4” pipes that make up that field.
Instead of digging it all up and removing it and installing All-New …. I’m thinking ..”Why not just dig trenches alonside the existing (plugged) pipes….. And lay New perforated pipes alongside the old…. re-connect the main drain line to the New pIpes…. OR…simply install al “jumper” or connector…to the originals for the new pipes to gain access to the effluent..?
I’m on private land. No neighbors.
Any suggestions on this?
BTW… I’ll be installing a “sister” system at the other end of my home for those “guest rooms” that still served by an 80 yr old system that needs updating. It’s a completely Separate system… but will require new tank and drain field.
It’s been suggested to simply Combine the two tanks to drain to a single drain field.
Any thoughts on that idea?
