Anybody got a suggestion on how to remove a seized front axle pivot pin on a 2wd L225? I am trying to replace bushings, but can't get it apart. Looks like the head of the pin was broken off by a previous owner, and there is a tang welded to the end of the pin in order to turn it. Won't budge. Tried heat (although not red hot), rapped on the pin and the spot where it goes through the front axle support casting. Set screw is removed. No problem with that.
Thx.
Thx.
