Seat Position for Extended Time Outdoors?
TractorZoo
2024 L3560HSTLE, LA805; 2004 L3430HST, LA723; Various older tractors
Apr 26, 2025
What is the recommended position for the operator’s seat when a tractor is outside for extended periods?
Should it be tilted up & towards the steering wheel or left down in the operating position?
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,730
2,075
Near Lancaster, PA, USA
Hate to leave a tractor in the elements. When I was in that situation, a heavy black plastic bag over the seat and secured was the ticket. When I worked construction, we found black bags were better than clear to lessen the condensation.
NorthwoodsLife
Oct 15, 2021
1,411
1,468
Wisconsin
Flipped forward over the steering wheel. Always. Every time.
Left in the seated position it gathers the sun and the seat material degrades. In the rain or snow it pools and soaks into the foam once the vinyl cracks.
Not even that; On a hot or raining day do you want to sit in a hot or wet seat?
TractorZoo
Apr 26, 2025
Thank you for the replies.
My 3430 has been outside year’ round for about the past 10 years and I always flipped the seat. After about 7 years of that I had to replace the “AIS” switch (operator presence) under the seat. I thought that it failed prematurely due to exposure to the elements more so than had the seat been down.
Chim’s recommendation should cover all the bases.
drygulch
L3901, LA525, ever changing attachments
May 30, 2024
152
211
Alabama Foothills
www.ebay.com
If I leave the tractor for a few minutes and don't tilt the seat up, it will either rain all of a sudden or clouds split and the blistering sun comes out.
Long term though is less about your ass, and more about the seat. Avoid the elements best you can. Trash bag or otherwise.
Greg
2,318
I fold mine forward and when parked put a plastic tub over the seat and steering wheel to keep it somewhat protected. There have been some that used pickup truck bed liners (discarded for some reason) to hang over the ROPS and hood To make a sort of shed. I park mine under a steel hoop shed with a plastic tarp stretched over the frame.
The tub is something like this. It is also used as a spill guard when changing fluids in the tractor transmission while catching 5 gallon bucket fulls.
Blue2Orange
Apr 3, 2025
167
94
Bayview Township
For whatever reason. I'm a bird poo magnet. Actually not me personally. Don't remember the last time getting hit. Just the truck, the boat, the tractor if not parked under cover. Even then. Some of the critters will just perch and drop a load. Burnt butt, wet butt, poo butt. Or just park everything inside when not in use. Seagulls and Canada geese are my nemesis. Never look up with your mouth open when you hear them.
