Safety Switch failure determination
Perry Keith Smith
z724 mower, L3740, finishing mower, tiller, front end loader
Jun 16, 2026
Alabama
I have a Z724 zero turn mower.
I replaced the starting coil the other day and it started right up. I cut for about half an hour and when I got to the end of the driveway I stopped and did not have the blades engaged and when I got up the mower died. I have not been able to get it started since, The relays click and engine light is on but the starter does not engage. So I wanted to test it and bypass the entire saftey switches to see if that was the problem. If it is then figure out how to which one it is by tracking down the wiring,
I just do not know which wires will bypass them all or if its a relay. so if anyone can tell me I would appreciate it.
lmichael
Kubota G2160
Apr 23, 2021
838
433
Rockford IL area
If you think it may be starter or battery you can bypass it all if you CAREFULLY jump the starter solenoid. If that starts it you know battery and starter are good. Then get out your trusty Fluke and have at it
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
897
879
Amsterdam, NY
If you don't already have one you can download the Workshop Manual HERE.
It has all the diagrams you'll need to trace electrical problems.
jaxs
B1750HST
Jun 22, 2023
1,043
793
And since you had to ask how to do it, DPDT on diagram means double pole-double throw , SPDT single pole-double throw and right on down the line. Study how these switches work because it can be confusing if switches are thought of as simply on and off.
I may be sued if someone steals my tractor and inures themselves but I totally disabled reverse safty. IMHO I believe messing with reverse over-ride and/or disengaging pto is riskier than looking over your shoulder while keeping hands on the wheel and mind on business.
