Kubota Newbie
Ok, Vic, if you're out there I need some advice on this one. Is there a trick to changing the front glow plug in an M4500 w/ the S2600 6 cyl. ? There is no way I can see to reach it without taking off the third injector line from the pump, even then, you can't get a wrench on it and it looks too close to the intake manifold flange to get a socket on. Special tool????
BTW, the back 5 were no problem and the indicator is glowing red inside of 20 seconds on a 20 degree day now. BUT, I still have one heater still in its box in the garage. Feel like I ought to change them all.
