i think you all are right. I have always thought it was a fuel problem. I think i am going to install a fuel filter with water seperator. This model has 2 inline filters no water separator. Also going to go ahead and clean fuel system
. I will let you all know how it turns out. Thank you!!
I think you are on the right track. Also consider where you are buying your fuel, and if it is likely to be a high turnover place that provides clean fuel.
I had a bad experience buying off road from a place nearby years ago. It clogged the fuel filter on my B2910. Was really strange, as the tractor was only months old. Decided to change the fuel filter on a whim, before having the dealer pick it up. The filter was blocked solid, could not blow air through it with my mouth. BUT the tractor ran fine for a while, then about died, recovered for a while, then repeat.
Only mentioning this because it still amazes me, and causes me to think your issue may be related to clogged filters, and that perhaps you might want to consider a different source for your fuel. I ended up just using on road since off road was a distance for me and not cost effective to buy when time and gas cost was figured in.
