Runs for 30 minutes, stalls
broklan
L3010
Oct 3, 2011
10
middletown, ri, usa
My 2002 L3010 (800 hours) looses power and stalls after 20-30 minutes. I changed the fuel filter and both air filters. Any suggestions are greatly appreciated.
phildac
1984 B8200E, L260F
Jul 29, 2009
203
Wentzville, MO
Make sure the tank cap has a good vent. A non-venting cap could be causing a vacuum in the tank restricting the fuel flow. After it shuts off, listen for a hiss when you loosen the tank cap.
8,467
What exactly happens?
Does it die all of the sudden or does it get weaker and weaker and just bog down?
All of the sudden I would suspect the fuel shut off solenoid is failing, or maybe a seat switch that is just on the edge of ajustment.
Bogging down and dying, I think Plugged vent in the fuel cap or maybe a bad lift or fuel pump.
gpreuss
Oct 9, 2011
1,166
Spokane, WA
How long before it will restart? Is it working hard, or hardly working? Temperatures normal?
broklan
L3010
Oct 3, 2011
10
middletown, ri, usa
Thanks all for replying. The tractor bogs down / loses power and stalls. I then leave it for 15-30 and use it again, normally to then put it away. If I try running it immediately it'll start then stall. I have not tried other delta times. It happens whether its working hard or hardly working. The temp gauge reads normal.
gpreuss
Oct 9, 2011
1,166
Spokane, WA
Nothing other than the gas cap fits the problem. Removing the gas cap should fix it right away.
mendonsy
B7500HST/LA302
May 28, 2012
357
34
Mendon, NY
Yeah, that sure sounds like a fuel cap that isn't venting.
Next time it stalls open the fuel cap a little and listen for it to draw in air. If it does then the vent is plugged. It could be dirty or a spider built a nest in it.
After you remove the cap it should start again.
pmhowe
L4240, Ford 8N, Kioti CK 2610
Jun 23, 2012
117
Banner Elk NC
I think it is a fuel starvation problem. As others suggest, it is most likely a plugged fuel cap. That is the easiest place to check, also. If that doesn't correct the problem, look for a partially blocked exit from the fuel tank, or a filter that is partially plugged, etc. Good luck! Tell us what actually caused the problem.
GWD
M7040, L48 TLB, BX2200
Jan 8, 2010
792
17
Northern California
Here is my all time favorite answer to these symptoms.
"Make sure nobody put gasoline in the tank instead of diesel fuel."
Gee, wonder how I would know that? :mad::p
Sometimes the gas can be smelled right at the tank.
You might try a fuel drain and refill with fresh diesel to eliminate the possibility.
broklan
L3010
Oct 3, 2011
10
middletown, ri, usa
thanks for all your help, it's taken me awhile to check the vent suggestion... no, when it stops running there wasn't a hiss while opening the fuel cap and the machine would not run immediately afterward. I have changed the fuel filters and air filters. Is there a 2nd filter or screen that may be clogged? thanks again
Wrencher2423
91
Leechburg,Pa,U.S.A
I had the same issue on my riding lawn mower(gas) but it was the electric shut off in the bottom of the carb. There was a needle that shut the fuel of for transport and was shorting out after the motor got hot. Unplugged it and threaded a bolt in the hole and has been great now for over three summers. My help
phildac
1984 B8200E, L260F
Jul 29, 2009
203
Wentzville, MO
Guess it could be possible for the vacuum to go away after the engine dies but isn't sufficient time for the fuel to refill the filter bowl. Is there any way to loosen the cap when nearing the 30 min mark to see if that makes a difference?
