running with hydraulic lines disconnected
MrMarkSH
L4701, top-n-tilt, loader, gannon, rear blade
May 7, 2023
Southern California, USA
Forgive the hydraulic newbie here, but this is a question even the dealer seems to have trouble with.
If I switch rear attachments, and disconnect the Top-n-Tilt lines -- leaving them connected at the cylinders, so they are closed -- and use these remote ports for a different attachment, will the T-n-T cylinders drift?
old and tired
1,919
1,297
Depends on if you have any internal leakage in the cylinder (oil bypassing around "O" rings) or if the disconnects "O" rings hold the pressure (they should).
I would add that (in my experience) when I disconnect hydraulic lines, male connectors rarely leak but female connectors weep a little bit of hydraulic fluid. Don't know if one (male/female) holds better than the other.
7,231
Far more likely when they are connected.
