My steering box turned out to be home made out of a stock worm gear reducing box. I found a used steering box and bought rebuild parts except for the column because I already had the column. Which is lucky because I couldn't find a used column. Took apart the old steering system last night to prep for the install of correct parts. But I noticed that the steering column has been cut short at the top. There is about 5.5" from the end of the column to the end of the steering rod. Does anyone think this might b e a problem? Can I use it that way? or is there some unforseen issue I might have.
Also, my steering wheel has no spline or anything. The only thing that was holding it to the stem was a cotter pin. Anyone know a source for a used steering wheel?
As it turns out, the worm gear reducing box is actually in preety good shape. Nearly all of the play in my steering was likely because of the cotter pin attachment method.
Drained the transmission fluid and found that one of my filter screens was torn off of the bolt. Doh! A new one is on order.
