Running in 4WD
Frank46
L3800 La524 loader
Nov 4, 2013
87
new Iberia,LA
Would keeping a brush hog hooked up to the three point provide the extra ballast needed when doing FEL work be ok. It's a woods for a L3800. Thanks Frank
GWD
M7040, L48 TLB, BX2200
Jan 8, 2010
792
15
Northern California
Anything works better than nothing.
The only problem with using an implement is the maneuverability issue. If you are working in a wide open area then a mower would work fine as a counterweight. A box blade, rototiller, etc. are usually pretty heavy also.
Tight areas would cause problems with incidental contact and damage to the implement and/or the thing being hit.
