Rubber "bird's beak" on BX air filter canister?
JackJ
BX1870-1
Mar 14, 2016
264
9
Indiana
I was checking my air filter yesterday, and reminded that I have no idea what the rubber thing does that connects to the lid of the air filter canister. Kind of shaped like a birds beak. In searching I've found one mention that it's a "dust release". Despite my filter getting dirty, I've never seen any dust or dirt accumulate in this part, and even if that is its purpose, I'm not sure I understand why it's designed to collect, rather then expel, whatever makes it that far up the air intake.
Please enlighten me!
Thanks,
Jack
JeffL
B7200E, B4200DT
Jan 8, 2016
344
North Central Ar.
Without a picture just guessing but, from the description I think it is a one way water valve. Water can drip out / closes so air and muck can not enter. All my cars have them in the bottom of the air filter box and at the end of the four sun roof corner drains. All must have the twigs, leaves and muck cleaned out every few years.
2,898
Thanks,
Jack
Jack,
if the canister collects a large amount of dust, when the vacuum of suction "stops" when machine cuts off - Or as the pressure decrease in the engine, it will empty. ALWAYS make sure it points downward too, typical filters caps can be placed on wrong side up!;)
read this to help :
https://www.google.com/patents/US4388091
JeffL
B7200E, B4200DT
Jan 8, 2016
344
North Central Ar.
That is a very fancy version of the simple duck bill device I was thinking. Of course the devices I have don't pass dirt or tree parts well.
Is this the dust drain the OP was referring to? Jeff
Magpiesn5
Perth
Hi Jack not sure if you have heard of Donaldson before but they make air filters and filter housings and a range of air and exhaust parts etc they call the device you describe as a vactuator valve the previous replies are correct in saying that it’s purpose is to release dust from the filter housing they play an important role in the first stage of cleaning the air before it gets to your air cleaner element if the are damaged, old etc they can actually let dust dirt etc to be sucked into the air cleaner and shorten the service life of your air cleaner see the attached link for some information http://www.donaldsonoemfiltration.com/library/files/documents/pdfs/055477.pdf
4,520
By golly I just learned something new,,thanks much digger
dandeman
BX2230, LA211 FEL, RCK60B Mower, GCK60BX Bagger; Ford 4000, bush hog, blade, etc
Aug 9, 2013
166
Chapel Hill, NC
www.dan-de-man.net
Thanks Magpiesn5 for best documentation yet on these... I see your location in Perth... as in ozzie land? Austraila makes some of the best equipment for 4x4 off road or overland vehicles.. not surprising with the huge desert areas there.
Also called a duckbill valve and many other names..
The pulsating air intake generated by each piston down stroke pulling in air and then the intake valve closing causes a brief period of vaccuum at the birds beak followed by a pressure wave created when the valve closes, causes a brief burst of air to blow through the birds beak, expelling accumulated dust.
Many different design variations are found on cyclone separators, designed to remove particulates from the air flow. Handy for use on off road vehicles to remove some of the dust particulates ahead of the air filter to maximize air filter life.
The vacuator valve design shown in the above post is similar to the design of the valves in our heart.
More on Donaldson filters here for off road vehicles.. https://snorkel4x4.com/en/content/8-cyclone-prefilters
https://en.wikipedia.org/wiki/Duckbill_valve
JackJ
BX1870-1
Mar 14, 2016
264
9
Indiana
Thanks for all the helpful replies! I could not intuitively understand how this thing functioned, but with the above explanation regarding pressure pulses in the air intake, I get it.
Here's a web image from another forum that shows the part on a different motor--the gray piece on the filter housing lid:
William1
BX25D
Jul 28, 2015
1,295
485
Richmond, Virginia
Never too old to learn.
I had thought they were just one way valves to vent water. It never occurred to me they could expel dust as well. But the operation makes sense. Now I feel even more compelled to double check the lil' BX.
Thanks for the lesson. :)
dandeman
Aug 9, 2013
166
Chapel Hill, NC
www.dan-de-man.net
Did that anodized and painted black air filter bracket come on your tractor pictured above?
My BX does not have that and the whole air cleaner assembly vibrates like crazy at various engine speeds. I think Kubota made a retrofit bracket to fix that...
Currently using bungie cords to tame the vibration.
JackJ
BX1870-1
Mar 14, 2016
264
9
Indiana
Sorry--no idea what tractor is featured in that photo. I stole the pic off the web, and apart from the filter canister, it looks nothing like my BX.
2,898
JeffL
B7200E, B4200DT
Jan 8, 2016
344
North Central Ar.
Well that is interesting. The drains I was talking about look similar but are only about 1/2" in diameter. I can see how something that diameter would be opened by a diesel intake pulse. Jeff
3,291
The Yamaha Rhino has ones like this on the CVT housing, and the cool air ducting for the CVT housing.
