For those people running rtv's there has been an increase in the torque spec for the nut on the rear axle. we have had some spline failures here so this is likely important! Remove the plastic hub cover in the center of the rear wheels, remove the cotter pin and torque the nut to 140 ft lbs (both sides).
Kubota also have a new drive shaft available for the front drive (transfer case to front diff) It is reasonably priced and a vast improvement over the original!! (same style as rtv1100)
Ed
Ed
