Rotary Cutter
JAbe
Kubota LX2620, Land Pride RCR1860
Apr 15, 2026
Durand, WI
I have a Land Pride RCR1860 rotary cutter. How do I remove the PTO/Slip clutch from the implement?
I have removed the bolt that holds the pto/clutch to the shaft from the gear box. Clutch is not froze to the gear box shaft. rotates easily. I can pull on pto/clutch and it easily moves 1"-2" on gear box shaft then stops. Is there a retainer clip or something I am missing? Can't see very well due to plastic shield that covers clutch area. Unfortunately this shield can not be removed until the pto/clutch is removed.
#40Fan
512
360
Probably some build-up on the end of the shaft that is stopping it. Give it a little love tap with a dead blow.
