Rotary Cutter
Clt1bkc
Kubota MX5400 Rops
Jun 27, 2020
36
Tigerville, SC
Using rotary cutter for first time. I have a area that had lots of Kudzu. What’s your experience with the rotary cutter and Kudzu?
Bmyers
May 27, 2019
3,337
3,942
Southern Illinois
I had to look up Kudzu, didn't know what it was. Closest thing I have cut that comes to that is black berry bushes and the cutter did fine. Will be interested in hearing from those that have actually dealt with that plant.
In Utopia
L175 FEL
Apr 21, 2013
621
130
Utopia,Tx/Pasadena,TX
I would think since it's a vine it may want to wrap around rather than cut like brush.
I used to live in Alabama, and man, that is some nasty and fast growing stuff.
BigG
Sep 14, 2018
1,951
772
West Central,FL
First I think I would set the mower down low to the ground so that you cut it near the roots and then I would come back in a few days and mow it again to cut up the stem after it has dried out. Perhaps that will keep it from wrapping around the stump jumper.
Take a sharp knife, side cut pliers, maybe tin snips to cut the vines off of the PTO. Do not let the PTO shaft stay wrapped in the vines very long. They will get harder to cut off the longer you run with them on there. They will also grab the next piece of vine easier.
Watch as you drive over the vines for ones that go up a tree and are wrapped around dead branches. As you drive over them the extra pull can cause the branch to fall, maybe on you or the tractor.
Depending on how thick it is you may be better off backing over the vines. Be careful as the vines may hide thing that you do not want in your mower. Go slow and chop away.
SDT
multiple and various
Apr 15, 2018
3,277
1,058
SE, IN
Rough cut rotary mowers are made for such tasks.
Keep the blade speed up and the ground speed low enough to allow proper clearing.
A cutter with adequate grass clearance will clear much better allowing higher ground speed, HP permitting.
SDT
BIGO
M5660suhd X1140 RVT
Sep 13, 2018
17
19
Fl
Forget the cutter, Spray it with rm 43 . The stuff grows about a 12" per day
aaluck
Oct 9, 2019
949
780
Snowdoun, AL
I'm in Alabama and BIGO is absolutely correct. I'm sure you could cut it fine with the above suggestions but it will return thicker and mad.
I'd spray it dead. Depending on your location and land permitting burn it once dead. If burning is not possible (safe) then I'd come back over it with the BH to clear it out.
B737
LX3310
Jun 9, 2019
2,024
2,201
+3 you have to mechanically remove it, and the follow up with serious herbicide. Cutting is not going to be a log term solution, and could just make it worse.
I was battling (and won) a highly invasive Japanese knotwood issue on my property. Wasnt until I physically removed the root system, and used a commercial grade 'ground clear' did it erradicate the problem. It took a few growing seasons. In England (i think) some of these invasive species are required to be buried 6 feet underground or burned.
Creature Meadow
Sep 19, 2016
1,065
140
Central North Carolina
It is bad stuff, lot of it here in Eastern NC. Little history below on it.
I have never tried to mow it, luckily none on my property, good luck with it.
Kudzu was introduced into the US in 1878 from Japan as a Centennial Exposition in Philadelphia and New Orleans in 1883 during an exposition. The plant was widely marketed as an ornamental plant that would provide shade for porches as well as a high protein content for livestock fodder and as a cover for soil erosion in the 20th century.
Tire Biter
B 2601 434 loader MMM, bunch of tractor stuff . Ford 4600
Jul 10, 2012
235
88
S.E. TN
There’s whole fields covered in the stuff here. Too bad there’s no use for it. Even drought doesn’t kill the stuff.
BigG
Sep 14, 2018
1,951
772
West Central,FL
This thread got me to thinking again about ways to control some plants or mow steep embankments. I just was reading that the goats will eat Kudzu. Maybe you could overgraze with the goats to control it. It says burning will only kill the young plants. The root ball can weigh up to 400 pounds. So digging it out may not work to well. The articles seam to agree to cut it and then spray with the weed killers.
B737
LX3310
Jun 9, 2019
2,024
2,201
you cant kill it, you cant make it go away, yet i cant grow grass in my backyard no matter how much i baby the stuff. Why cant someone make turf grass out of this DNA??? :)
aaluck
Oct 9, 2019
949
780
Snowdoun, AL
I'd like to see a photo of the area we are talking about. Just for reference. Is it overtaking trees? Mainly ground?
Nicfin36
Jun 19, 2019
1,018
469
Decatur, AL
Goats will absolutely eradicate it. My grandfather had about 10 acres of it. He fenced it and put goats in it and I guess the little devils never gave it a chance to grow as they nibbled it out of existence. It never came back.
dvcochran
Kubota M9000, New Holland TN90, Deere 2640, Vermeer 504N, Vermeer 504SI, more
Feb 23, 2011
213
45
Dickson, TN
I've never heard of the plant, so went to look it up. This young man came up with a solution to get rid of it.
That is an amazing article. Have you found any large scale use or commercial products to use helium this way?
