Using rotary cutter for first time. I have a area that had lots of Kudzu. What’s your experience with the rotary cutter and Kudzu?
Rough cut rotary mowers are made for such tasks.Using rotary cutter for first time. I have a area that had lots of Kudzu. What’s your experience with the rotary cutter and Kudzu?
I'm in Alabama and BIGO is absolutely correct. I'm sure you could cut it fine with the above suggestions but it will return thicker and mad.Forget the cutter, Spray it with rm 43 . The stuff grows about a 12" per day
+3 you have to mechanically remove it, and the follow up with serious herbicide. Cutting is not going to be a log term solution, and could just make it worse.Forget the cutter, Spray it with rm 43 . The stuff grows about a 12" per day
you cant kill it, you cant make it go away, yet i cant grow grass in my backyard no matter how much i baby the stuff. Why cant someone make turf grass out of this DNA???There’s whole fields covered in the stuff here. Too bad there’s no use for it. Even drought doesn’t kill the stuff.
That is an amazing article. Have you found any large scale use or commercial products to use helium this way?I've never heard of the plant, so went to look it up. This young man came up with a solution to get rid of it.
