Rotary cutter rear wheel concern
RickandBecky
Kubota M4900SU
Sep 21, 2020
23
Tyler, Texas
Hope this post is allowed, as it is related to a non--Kubota implement, my BushHog 286 rotary mower. (I do have an M4900 Kubota Special Utility tractor that I pull the mower with). The rear tail wheel which support the mower has begun to ‘stick’ in a sideways position when I turn at the end of a mowing row. When it does this, it will plow up a furrow of grass and soil until I lift the deck and straighten the wheel. Needless to say, this is aggravating and time consuming. I keep the wheel lubed, and both the wheel itself and the swivel it’s mounted on seem to move freely when lifted from contact with the ground. This has just started happening recently, so looking for some advice as to what is causing this and how to remedy it. Thanks for any advice or help!
kubotafreak
Sep 20, 2018
1,022
374
Arkansas, US
Is the fork bent at all? They don't last long when you hog much in reverse.
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
With the deck lifted try pushing the wheel up to contact its normal placement with the deck lowered. Try turning it to see if you can detect what's binding. You could also play with the up and down on a paved surface working the wheel by hand while the tractor is stationary.
SDT
multiple and various
Apr 15, 2018
3,084
926
SE, IN
Fork or more likely spindle is bent from backing into obstacle(s).
It will not caster properly until it is straightened or replaced.
SDT
