Would it be possible to make some kind of cutters that can cut roots of trees (up to a few inches thick)(im thinking of like a BX or B tractor) by taking off the backhoe bucket and installing a cutter on the end of the backhoe arm that uses the end cylinder for moving a cutting blade ? maybe made out of thick flat stock incase you would accidently get stones in there so you wouldnt be wrecking expensive, high quality metal blades. The fixed side would be 2 pieces of metal and the other side of the cutter would be sandwiched in between them and pivot on the same axis (bolt or pin) ...?... just wonderin ....hmmm .... the things you think of when ur bored ....
