Rolled a tire off
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
1,810
888
Near Lancaster, PA, USA
Was making a run along the edge of the road to clear the shoulder for the postman. Looked down at the RF tire and saw it was half off the rim. The outside tire bead was off the outside of the rim. Fortunately it was an easy fix. It was simple to use the FEL for a jack and pull the wheel. That R4 was way to stiff for me to try to remount it at home. Ran it to town and $10 later was back at work.
I checked the RF tire and found it only had 15# in it, so I'm now running 30# in the fronts:
Reactions: 6 users
ctfjr
L3800HST
Dec 7, 2009
1,739
1,977
central ct
I popped a bead on my last tractor in the woods coming up against a large rock. Since then I run 25psi, at least, all around.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
595
448
E.
good to hear someone was around to help you... $10 is a steal.... helpers are priceless.
SDT
multiple and various
Apr 15, 2018
3,089
932
SE, IN
Rolling a rear tire from the rim, almost always due to underinflation, is a leading cause of equipment rollovers when operating on hillsides.
Yooper
3901 LA525
May 31, 2015
1,464
433
NE Wisconsin
Welcome to the club! Did it on a rear tire and it was absolutely no fun!
chim
Jan 19, 2013
1,810
888
Years ago I had that happen with a B7500 rear and it barfed its windshield washer ballast. Was helping #1 Son make some parking spaces. Apparently the amount of traction was enough to overcome the marriage between the tire and rim. Since the tire beads both remained on the wheel, I was able to expand it enough with a ratchet strap to get it seated and re-inflated.
