Rkc54 mower deck
2,842
Looks like a deflector from a snow blower (says a guy from Texas that has only seen pictures of snow blowers).
Caden
1979 B7100
Apr 16, 2026
70
29
My guess it that it came from under the tractor rather than the on deck.
Such as a mid pto guard, hydrostatic fan guard, etc.
A picture of your deck or under the tractor would be helpful.
JimDeL
BX2380; 54" MMM; FEL w Pirahna bar; Ballast Box; BXpanded skid plate.
Aug 31, 2022
453
528
NE Ohio
It's part of the deck adapter kit. It bolts in under the deck, just forward of the discharge chute. It helps direct the flow of cuttings into the collector. If you're not using the vacuum/collector you don't need it.
Actually, even when I'm using my lawn/leaf vac I don't install it. The system works fine without it.
ChickenLady
Bx23s
Sep 19, 2024
That must be it! I have no clue why it was installed when I didn't have a lawn/leaf vac or collector of any sort. I ended up taking it off and ran it fine without it. Thanks so much! I'm still learning so much about this stuff.
ChickenLady
Bx23s
Sep 19, 2024
Yeah, I thought I took a photo before I took it off, but had already flipped it over after removing it and didn't want to lift it again. It was stupid of me not to.
