I have a hydrualically operated snow blade on my B2620 tractor.
After pinching and bursting the hose that lowers the blade, I purchased a new hose and some Super UDT fluid from my kubota dealer.
I replaced the hose; added fluid and then attempted to bleed the system by leaving one end of the new hose disconnected and moving the blade until only straight fluid (no air) came out.
I then connected the loose end and operated the blade.
It turns left and right okay; goes up okay; but, while the blade does go down, it does not have nearly the power/strength in the down direction it had before the hose bursting. It used to be able to lift the front end of the tractor - not now. Did I do something wrong or miss part of the bleeding process? Did I connect the new hose wrong?
