Replacing cylinder liner in D1105
sportscarclinic
B2150 w/LA350A and BT750 - B6000 w/S6000 - B7100 - B7200 w/B1630
Apr 11, 2017
25
Portland, OR
Anyone have a method to remove the liner from the cylinder block in a D1105?
I've tried MIG welding 5 spaced beads down the length of the cylinder walls hoping the liner would shrink and loosen when it cooled, but no luck.
SidecarFlip
Banned
548
SMAW and high amperage. Mig don't make enough heat.
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,115
Hardisty, Alberta
I don't think the D1105 engines have replaceable sleeves. I did bore one out a few years ago and installed a sleeve to correct a score in the cylinder wall.
4,424
Eserv, if that's the case, he probably has a couple of scores in the cylinder wall!!
5,215
Yikes, all the information I have is it's NOT a sleeved engine.
Pictures please!
FYI: You might be dealing with a different version than I'm normally seeing, there are rare versions of a lot of different Kubota engines out there, it might help to know what it's used or was used in.
SidecarFlip
Banned
548
Pictures please!
If it isn't he's screwed big time:eek:
